RoadMaster wagon odometer lights
Old May 13, 2018 | 09:20 PM
Bentwings's Avatar
Default RoadMaster wagon odometer lights
i really like my “new” Estate Wagon but it’s almost impossible to read the odometer without a flash light. How do I go about fixing this? There are lights there but they are so dim as to be useless.
BYRON
Old Jun 5, 2018 | 07:45 AM
Fred Kiehl's Avatar
You may have a bad dimmer switch. Do the rest of the bulbs light up properly? The lights for the odometer may be burned out, and you are getting spillover from other lights in the cluster. To replace bulbs, you must remove the dash front, to get to the cluster.
Old Jun 5, 2018 | 08:53 PM
Bentwings's Avatar
Thanks, now I’ll be totally ignorant,
jusy how do you get the dash front off? I did look around for fasteners but I’m lost.
thanks
Byron
Old Jun 5, 2018 | 10:14 PM
Fred Kiehl's Avatar
If I recall there are a couple of screws above the cluster, and then the rest is just held on by "pins". Once you get the screws out, it just pulls off, Do be careful, it is plastic.
suedotcom
Jan 3, 2019 07:22 AM
Scottintexas
Dec 22, 2011 10:34 AM
johnelwayfan7
Sep 25, 2008 01:55 PM
Dustydog
Jan 21, 2006 06:07 AM
ray97
Jun 4, 2005 12:56 PM
