No heat on passenger side ater blend door replacement
Old Jan 7, 2025 | 11:20 PM
Tarrelton Peffer's Avatar
Unhappy No heat on passenger side ater blend door replacement
I am getting no heat on 2004 CXL passenger side. I have a new coolant temp sensor, thermostat, and dual climate control, still not heat. So I changed my blend door, the old on had come off the plastic lever tack that the arm rides in. Had hard time mounting the blend door arm to the plastic lever, it came loose, and I re attached it. Blend door installed moving in lever track with the movement of the temp controls on the climate control still no heat on passenger side. Its cold and this on has me whipped at the moment. Any idea's or help will be greatly appreciated.
DIYallthetime
Aug 29, 2013 06:40 PM
schzjoe
Mar 15, 2013 01:53 PM
JOEVETTE19
Dec 7, 2009 01:01 AM
jrasche2003
Apr 3, 2007 02:12 PM
Ozone Ranger
Nov 4, 2006 06:05 PM
