A few quick notes on replacing the Blower Motor on a '06 Rendezvous
Hello all,
I'd like to post up a few quick notes outlining a very general guide to replacing the blower motor on a '06 Rendezvous
I may supplement this outline with more in-depth content in the near future:
1) Remove the right side instrument panel insulator.
2) Disconnect the electrical connector from the blower motor.
3) Remove the blower motor mounting screws.
4) Remove the blower motor from the HVAC module assembly.
-Installation-
1) Install the blower motor to the HVAC module assembly.
Note: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2) Install the blower motor mounting screws and tighten the screws to 16 inch lbs. (1.8 Nm).
3) Connect the electrical connector to the blower motor.
4) Install the right side instrument panel insulator.
The blower motor is depicted as ref #33 in this diagram:
I may supplement this outline with more in-depth content in the near future:1) Remove the right side instrument panel insulator.
-Installation-
BuickBag
Jul 29, 2011 11:15 AM
