2006 Rendezvous Manual Lever for seat recline.
Old Nov 10, 2013 | 12:34 PM
William Morton's Avatar
Default 2006 Rendezvous Manual Lever for seat recline.
My 2006 Rendezvous Driver Seat Manual Lever to recline the is broken and it does not feel like it is connected to anything when I pull it. Is this a common problem with the Rendezvous?
The electric seat controls are working correctly only the manual lever that you pull up on is broken.
Old Mar 13, 2015 | 08:49 PM
Ruben Girona's Avatar
Cool Same issue
I was having the same issue but i took mine apart and found that this metal ring with a tooth to grab the bar was turning in the plastic handle. I just drilled a small self tapping screw through the other side of the tooth and vuala keeps the metal from freely moving. (make sure the screw goes through the plastic handle)
Feb 21, 2015 04:53 AM
MrChips
Apr 6, 2011 01:11 PM
rodram
Aug 16, 2009 06:30 PM
btferg
Sep 5, 2008 12:38 PM
torres
Jul 31, 2006 11:59 AM
