Stereo Replacement 2000 Regal
Old Nov 14, 2011 | 06:55 AM
  #11
Merc6's Avatar
You can ignore the dash shifter part I forgot you guys only have 5 seaters .
Old Nov 16, 2011 | 10:20 AM
  #12
feltes94's Avatar
so i learned that just back and maybe front driver speekers are blown if i tke them out of my 94 monte carlo would that work with the radio just fine for sound? i have aftermarked radio in the monte and speekers sound amazing in the buick i have the 6 speeker setup the bass kinda sucks in the buick so i was wondering if new speekers or put monte speekers in and new deck or not ?
Old Nov 16, 2011 | 11:49 AM
  #13
Do whatever you want. As long as they fit (6x9 in the rear, 6.5 components in the front), you should be good. If you want to just use a 6.5 2 or 3 way speaker in the front, you can do that too. There probably won't be much of a noticeable difference in the sound.
Old Nov 16, 2011 | 03:19 PM
  #14
Merc6's Avatar
The tweeters hook to the factory woofers so you will have to splice that.... also if you get the quick connects from worst buy they need to look like this.
http://i90.photobucket.com/albums/k2...6/641a1c0b.jpg
Well the ones you buy will be black and white. this the oem one from tweeters. The connectors are good for all 4 speakers. Tweeters gotta be spliced back into the mix.
This is how the fronts are. There is a spot where the wires slip past the speakers shown in the pic for tweeters.
http://i90.photobucket.com/albums/k2...6/34a1c13b.jpg
Old Nov 17, 2011 | 09:54 AM
  #15
feltes94's Avatar
yeah its the compII sound or what ever its called i going have save up some money first but ill have to look into that stuff do you thing a junk yard for speekers would be ok or better off getting aftermarket ones or something?
Old Nov 17, 2011 | 01:52 PM
  #16
Merc6's Avatar
If you can find a set there not blown. The fronts were like $35 and rears were I think $48 wal mart. The plug and play was about $32 for front and rear set at worst buy. I always get the plug and play for easier instal vs cut and solder. Later I will post the exact kit cause best buy usually gives you the wrong one. Not sure what year they changed connectors for the speakers, if the mote has the same size front and back size you might be able to get away with it. Same for radio and in dash kit but if it's like the century you might have to cut to fit.
Old Nov 17, 2011 | 02:30 PM
  #17
feltes94's Avatar
ok thank you ansd if you can post that connector for plug and play
Old Nov 30, 2011 | 10:00 AM
  #18
feltes94's Avatar
is there anything wrong with your stock radio? because i trying find new one cuz my casset dont work like dont eject all the time i am happy with the sound it s just the speekers r blown so i putting sony explodes in with stock radio how much is to much for one at a junk yard do you supose?
Old Nov 30, 2011 | 02:43 PM
  #19
You can probably get one at a JY for under $30. I actuallly like the stock radio better than anything aftermarket, especially if you have steering wheel controls.
Old Nov 30, 2011 | 08:45 PM
  #20
Merc6's Avatar
With the stock radio, there is a 60/40 chance it's still there in the car/truck/van cause theftlock is a hassle to deal with. You kinda have to take into consideration it could be in worse condition than yours. I found 2 exact radios but decided aftermarket double dins are my best option and Cruchfield has kits to keep the steer buttons. OEM radios here go for $24-26 depending on if it has a tape player or not. The yard I go to has warranty options on parts for an extra fee for the event it doesn't work. Supposedly 2001 or so they changed the radio connectors and radios in general making them non plug N play with the older ones. I hate my NON MP3 CD player skips every 5 seconds. My tape deck is broke as well but that's normal. I never had a walkman last more than a year when I was younger nor the tape decks in the Ghetto Blasters. I think they are rigged to fail like the resistors in the gauge cluster. There is a thread above us that has the way around theftlock if you want to venture that direction. My Xplodes are holding up fine but I would go with component set for the front door. The Xplode 4 ways in the deck love bass but the door 4ways are meh when it comes to bass but are lovely with mid and hi's. The built in crossovers kill the bass.
There was a few different kinds of radios depending on options of both new and old style. The following listings show the backs of the radio.
Newer radio back
http://www.ebay.com/itm/04-05-Buick-Century-Rendezvous-Radio-Cd-Cassette-10333584-/200681477956?pt=Car_Audio_Video&vxp=mtr&hash=item2 eb98c5744
Older radio back
http://www.ebay.com/itm/1996-2003-Buick-Radio-Stereo-Tape-Player-Century-Park-Avenue-Lesabre-Regal-/190588789086?pt=Car_Audio_Video&vxp=mtr&hash=item2 c5ffa215e
