Stall
OK here it is 92 Regal 3.1l
Every so often just coming off of idle my engine will stall. It starts right back up and then wont do it again for a while. It runs flawless otherwise(no missfire or bogging). It has 144'000 miles on it fresh tune up and fuel filter and pump. I am very confused cause there is no rhyme or reason to this besides only when you got to accelerate off of idle.
Intermitten stalls are most likely caused by a bad / dirty connector to a sensor or module.
Try removing the ICM connector and clean and tighten up on the sockets.
Then procede to the rest of the sensors if it still happens.
Also a dirty IAC valve will cause a decel stall.
