Oil
Old May 8, 2006 | 10:41 AM
cdyer76's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I own a 1995 Buick Regal Custom. It is the 3.1L. I have a slow oil leak and it does not burn any oil. It has approx. 116,000 miles on it. I was wondering if anyone has suggestions on what type of oil to use. ex. high mileage, synthetic, blend, etc.
Old May 8, 2006 | 02:36 PM
MrBSS's Avatar
Personally, I don't see much success with the additives designed to stop oil leaks, however they are probably a better option than high mileage oils (which claim to do the same thing). They might be worth a try.
Synthetics have a reputation of being more prone to leak and, of course, you'd be losing a more expensive product. I assume synthetic blends would be similar.
Consider going up a step in viscosity (eg.: 10W40), depending on the climate you're in. And just get the cheapest SL(SM if SL not available)rated oil you can find. If its something easy, like valve cover gaskets, you'd probably be better off to just fix it. Edited by: MrBSS
Old May 10, 2006 | 10:55 AM
cdyer76's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Thanks for the reply, ill give that a try.
dhac
Mar 29, 2009 09:43 AM
buckroo
May 16, 2007 01:29 PM
archinth
Oct 25, 2006 10:07 PM
Ladd
May 25, 2006 03:17 PM
MrBSS
Oct 14, 2005 12:38 PM
