Low Tire Warning Light
Hi all,I,m new here and have a question.I have a 1997 Regal GS with 46,000 miles.Recntly the low tire warning light came on and I can't get it out.When it came on I checked the tires,one was ten pounds low. I set them all at 32 lbs,the tires only have 1500 miles on them.I tried to reset the circut breaker like it says in the owners manual.Still on.I replaced the circut breaker.Still on.I disconnected the battery for a few minutes.Still on! Any ideas,this thing is getting on my nerves and I just know a dealer will probably charge a bunch to fix it.Guess I could just put a piece of black tape over it.
Some of these are overly sensitive. All I can suggest is that you be sure the rolling diameter of allis the same, and that the reset has actually taken. This means exactly even pressure in the same tire with the same wear.
