engine not running right
Old Apr 7, 2005 | 11:43 PM
kewill_2000's Avatar
1989 Buick Regal Custom
3.1 V6
The engine will run but really rough. sounds like misfiring. I replaced the wires, plugs, igintion modual, coal packs fual filter, fuel pump checks out fine. Checked the TPS "<NOBR>Throttle position sensor" and disconnected it it ran better but is still dies when you rive on it.
</NOBR>Edited by: kewill_2000
Old Apr 11, 2005 | 01:49 PM
Patrick's Avatar
Administrator
how old is the catalytic convertor?
Old Apr 11, 2005 | 05:22 PM
Erakiel81's Avatar
it's can be as said Patrick a problem on the exhaust, like to many
restriction on gas flow. You can also try to clean the air intake
system and vaccum. Shooting carb cleaner in the throttle body often
help. You can also by cleaning stuff that will clean the vaccum part.
The stuff pass by the PCV valve.
Old Sep 11, 2005 | 04:52 AM
firefighter0029's Avatar
Check the firing order again just to make sure. Serioiusly. I've tuned
up cars a million times but the 3.1 are easy to get the wires crossed.
If it's not the cat try the crank sensor.
VanBuren
Feb 20, 2016 04:11 PM
petey882
Nov 23, 2010 03:38 PM
Ruroni
May 9, 2008 07:51 PM
iconoclast
Mar 24, 2006 01:52 AM
