Location of 1992 Lesabre Camshaft Position Sensor
Old Apr 12, 2009 | 10:57 AM
1992Lesabre's Avatar
Default Location of 1992 Lesabre Camshaft Position Sensor
1992 Buick Lesabre V6
Where is the Camshaft Position Sensor located?
One generic "diagram" shows top view indicating towards back from "crankshaft position sensor".
A different verbal description says:" Lower RH Side Of Engine, Above Lower Pulley". This description would appear to put it behind motor mount, therfore impossible to get to.
These two references disagree with each other.
Question:
My guess it is towards top of engine under the alternator.
See attached photo.
Is it true that if I remove the alternator I could see the camshaft position sensor?
Attached Thumbnails Location of 1992 Lesabre Camshaft Position Sensor-img_3177a.jpg
Old Apr 12, 2009 | 11:06 AM
Tsunamisephi's Avatar
Don't remove your alternator. The sensor cannot be seen from the top of the motor, as it's tucked into the back of the motor on that side. Run your fingers behind the motor near the small black pulley under the alternator and you'll feel an electrical connection into the motor. unlatch that and you have pulled out your sensor.
Attached Thumbnails Location of 1992 Lesabre Camshaft Position Sensor-img_3177b.jpg
tjcomptool
Nov 19, 2013 01:13 AM
Braath Waate
Jun 16, 2013 12:38 AM
wizzard1222
Jul 24, 2012 01:15 PM
GuidoBuick
Jan 11, 2010 12:31 PM
gonfiato
May 5, 2009 02:12 PM
