V8 engine require premium fuel?
Old Jan 30, 2006 | 06:04 PM
chgo29's Avatar
Can anyone tell me if the V8 Northstar engine used in the new Buick Lucerne would require premium fuel? Or can it burn regular 87 octane? Cliff
Old Jan 31, 2006 | 12:30 PM
MrBSS's Avatar
I think they do recommend premium fuel.
However, like most recent vehicles, you will probably do no harm if you use regular. This is because they have a sensor which retards the timing at incipient knock. So you will just get slightly less power at peak loads during hot, dry conditions.
Also, GM has usually defined premium as 91 octane, while premium gas here is usually 93. So you've got some margin if you occasionally use mid grade.
I guess I wouldn't admit to using lesser grades though, because they might use it as an excuse to deny warranty coverage.
Old Feb 24, 2006 | 02:27 AM
yankieepapa's Avatar
I'v had my new lLucerne CXLV for three weeks and it says wright in the owners manual that regular gas can be used. I traded in an Eldorodo touring coup that had the same engine and I used the mid range gas in it for 6 years. I'm now using regular in the buick and you can not feel any differce in the performance. I'ts a great running car. Vince[img]smileys/smiley17.gif[/img]
Old Mar 14, 2006 | 02:17 PM
bobf823's Avatar
I run branded unleaded (87), runs just fine with the Northstar
Buick Forum Editor
Oct 2, 2012 04:53 PM
