Lucerne 4.6 no crank no start
Old Dec 11, 2023 | 07:32 PM
Jefft's Avatar
Default Lucerne 4.6 no crank no start
Hi everyone new here I have a 2008 lucerne with a 4.6 it's been acting up while driving would just stall but would usually start back up yesterday it stalled and now has a no crank situation scanner shows no communication with ecm tcm and couple other modules I have no power to the no. 1 fuse ecm crank fuse I replaced ignition switch with no luck security light goes out few seconds after key is tuned on so no issues there gauges aren't working everything else seems to work all lights windows radio ECT any help as to check would be greatly appreciated thanks
Old Dec 12, 2023 | 01:35 PM
A no communication problem can be from no power avail to scanner.
Do you have any kind of electrical test equip like a multumeter?
Old Dec 12, 2023 | 01:45 PM
Jefft's Avatar
Yes I've done power and ground checks to the ecu and tcm can bus check at the diagnostic connector I've got 120 ohms with key off should be around 60
Old Jun 30, 2024 | 12:42 AM
Rubberneck's Avatar
Default Ever get it started?
Did you get it to start or what's up
BuickBag
Nov 11, 2024 08:26 PM
Humbo
Mar 17, 2023 10:10 AM
patcal
Jul 17, 2017 05:37 AM
prowler22
Oct 16, 2012 03:48 AM
tdavis
Apr 2, 2007 03:14 PM
