Stalls after starting.
Old Mar 27, 2017 | 01:00 PM
Countyline02's Avatar
Default Stalls after starting.
Hello. I'm trying to fix my mother in laws 2001 Lesabre. It will start and run for a couple seconds then die like I turned it off. It died while she was driving it. Had it towed wouldn't start. I went out to work on it but it started up and ran. She drove it a a couple times then it died again while driving it. Now it is stalling again after starting.
I tried unplugging the maf. No change.
Since it does fire and run for a couple seconds I don't suspect the crank sensor, I did try unplugging it to see what would happen and as I expected it will crank and not fire.
I read some where that if the oil pressure switch is failing it can shut the car down after starting for a couple seconds.
The car does have oil. I tested fuel pressure and it was good. I tried swapping out fuel pump relay-no change.
No codes. No security light. Does not have a ignition key with a chip in it.
Any ideas?
focusownerskid
Oct 17, 2007 04:08 PM
techmike
Jun 15, 2007 11:03 AM
MNM3461
Apr 3, 2007 05:35 PM
LOPEEE
Feb 16, 2006 03:57 PM
topn01
May 10, 2005 03:15 AM
