passenger climate control, 1993
I just bought a 93 LeSabre Ltd and it appears that the separate passenger climate control module(mounted on the passenger door) does not function.
Is there an LED screen there like there is next to the AC/Heater main control in the dashboard?
Thanks,
Dan
Edited by: dpm93
Don't have this in my 93 Custom, but I can tell you what the 93 FSM says.
"Passenger Climate Control Assembly
The passenger climate control assembly includes 2 soft-touch buttons and a bar segment display. The soft-touch buttons (COOL, WARM) are used to raise or lower passenger side outlet air temperature. The bar segment display is made up of 9 LEDs (4 green, 1 amber, 4 red) and indicates passenger-side outlet air temperature relative to driver-side outlet temperature. The passenger climate control assembly is activated only when the system is operating in the DUAL ZONE mode."
Hope this helps.
Hope this helps.
