left turn signal problems
Old Feb 7, 2010 | 11:43 AM
taranov's Avatar
Default left turn signal problems
My left turn signal was been flashing a lot faster than usual. Does anyone know why this happens and how to fix it? Is it indicative of a serious problem?
Old Mar 6, 2010 | 07:05 AM
big chuk's Avatar
It sounds like you have a bulb burnt out on the left side, or if you recently replaced one it may not be installed corectly. Turn your signal on & inspect the car to see if all of your signals are flashing.
Old May 24, 2010 | 07:42 AM
mnewbolds's Avatar
I had the same problem, mine turned out to be the parking light/turn signal socket in the front on the lower driver's side. $23 for the new socket and all is well. But it may just be a bulb. If the system detects a bad connection (blown bulb) it notifies you by flashing at a higher rate of speed.
chevez
Nov 7, 2007 12:17 AM
chevez
Sep 19, 2007 05:27 PM
Lee_in_WV
Jun 12, 2007 05:00 PM
POOPDADDY
May 20, 2007 09:17 AM
sixty7rs
Dec 7, 2005 03:16 PM
