Help with 1993 Lesabre AC recharge
One of the ways to locate the low side pressure port is to start at the compressor and follow the larger size hose back to the evaporator in the car and on that line should be the low side port. Also if it is a R12 system the larger port schrader valve is for the low side. The hi side port is smaller.
