cutting out 92
Old Nov 26, 2007 | 03:21 AM
jimmykicker's Avatar
Hi everybody...This is my first post!
I have a 92 model LeSabre with the sexy flaking green paint. It runs great.....except when it is between 75-85 degrees. Then after about 30 minutes of operation, it cuts out when accelerating. Not missing so much, but just cuts out when you step on it. Around 80 degrees it will runs so poorly when this starts, it will barely accelerate, and has nearly gotten me hit a bunch of times. It will straighten up if you cut it off and restart it, but that is only a temporary fix as it will come back in a minute or two. Occasionally it will do it above or below this temp range, but not usually, and a shut off usually stops its for the rest of the day. If it is really cold (below 45 degrees..) it will never do it for weeks?!?!? There are no SES codes present. Perhaps it is the temp sensor? Anyone else have similar problems? I have put new wires on it, new coil packs, and plugs with no resolution to the problem. [img]smileys/smiley5.gif[/img]
Thanks!!!
J
Edited by: jimmykicker
Tia
May 13, 2024 11:28 AM
Buick Forum Editor
Jun 12, 2015 07:29 PM
Buick Forum Editor
Feb 26, 2015 03:50 PM
Buick Forum Editor
Jan 25, 2015 04:13 PM
bigbob32
Sep 14, 2005 12:14 PM
