cank sensor
Old May 12, 2007 | 03:43 PM
zo97's Avatar
Where is the crank sensor located in a 97 lesabre custom?
Old May 12, 2007 | 11:38 PM
bowtieguy's Avatar
Facing the front of the engine, you will see it on the right side of the crank shaft. Mounted behind the balancer. You would have to remove the balancer to replace it.
Old May 29, 2007 | 06:12 AM
bassasasin's Avatar
To find the CRANKshaft sensor,
try looking from the passenger side of the car.
The CRANKshaft sensor is behind the passenger front wheel side of the engine under the engine harmonic balancer wheel at about the 3 'o'clock position.
The passenger wheel is removed and then the wheel well splash panels where the balancer wheel is visible and then removed to replace the sensor.
smshall
Jul 29, 2015 10:50 AM
wizzard1222
Jul 24, 2012 01:15 PM
heyzeus
Dec 7, 2006 04:36 PM
redlove
Nov 11, 2006 08:06 PM
john harker
Jul 26, 2006 09:41 PM
