2001 Lesabre Battery Replacement
Old Feb 26, 2008 | 03:56 PM
kingarfer's Avatar
I recently bought the Lesabre (and have a window regulator on order from ebay), shocking isn't it? Anyway, the vehicle has the original battery and I would like to replace it. I am probably going to get one from the dealer, to keep the right fit in the space under the seat.
My question is, if I install the new battery, is the stereo going to require some type of security code to get it working again? The vehicle came with no code.
Old Feb 27, 2008 | 09:25 AM
MrBSS's Avatar
Space under the seat??? I guess you mean under the hood. Any supplier will have a battery to fit your Buick. WalMart will sell you a battery that Consumer Reports has rated highly, for about half what your dealer will charge.
The stereo might require a security code. I believe that all those that require it will show a flashing red light when the ignition key is out. If you do have that light, it could need a code which the previous owner had set. There may be a dealer default code. Newer vehicles are keyed to the VIN (so you won't have the problem), but I don't know if yours uses that system. You can also buy a 9v battery connection which plugs into your lighter and maintains memory while the cables are changed,
Old Feb 27, 2008 | 11:56 AM
kingarfer's Avatar
The battery for the Lesabre is under the rear seat. Thanks for the info on the security code.
Old Feb 28, 2008 | 10:17 AM
MrBSS's Avatar
Oh, sorry! I have a similar Park Avenue which has the battery under the hood and assumed yours would too. Still, I would expect that others would make a battery for you. Its just that whenever I have to goto the dealer I end up spending more than necessary, so its kind of a last resort. They seem to charge you $100 fordriving in!
But on the other hand, your dealer should be able to give you a definite answer on the kind of security code you have, as well as how to reset it.
Old Mar 1, 2008 | 12:26 PM
samueljackson's Avatar
i believe delco is the only maker of that group size. IDK if the other manufacturers make em yet.
Old Mar 3, 2008 | 08:04 AM
kingarfer's Avatar
Thanks for the info. I got my window regulator replaced, and I didn't even break any of the plastic trim screws! I used the instructions I found in this forum.......saved me about $400.
earl53@yahoo.co
Jan 28, 2011 12:41 AM
scurbiedog
Oct 27, 2008 12:06 PM
Michail
Nov 20, 2007 10:26 AM
scurbiedog
Nov 29, 2006 09:12 AM
PA2005
Mar 24, 2006 02:04 AM
