1992 Buick LeSabre Limited - Help Needed!
Old Feb 23, 2015 | 02:08 PM
Drouse's Avatar
Default 1992 Buick LeSabre Limited - Help Needed!
Hi Guys,
I'm new to the forum but just ran into an issue with my Buick and figured what better place to ask than here.
The other night I was leaving the gym and while reversing out of my parking spot and car started to buck a little like it wanted to stall. As I put it into drive and head out it did then stall. I assumed it was because I ran out of gas (I was low at the time). I wasn't sure if it froze since it's been so cold or I just ran out. I started it back up and rev'd it up a bit and it was fine. Ran to the gas station up the street and filled her up. Assumed all was well.
The next day I went to start it early before work and the car will not start unless I'm on the gas. It turns over and starts but then dies right out unless I get on the gas. If I hold in the gas for a few minutes and rev it up it will continue to run but I should not have to do this. Prior to this I had 0 issues with the car. Any suggestions would be great. Also it seems to rev higher than normal now after running a while.
Old Feb 28, 2015 | 11:36 AM
bandit_60's Avatar
sounds like maybe the fuel filter is clogged up and needs to be changed ! i had to change the filter on my 97 lesabre
Crowsville
Audio/Visual Electronics
Jul 12, 2012 06:03 PM
jayhovah1982
Nov 20, 2011 02:49 PM
xpdude
Jul 6, 2010 12:41 PM
johnlivingston
Jan 21, 2008 11:18 AM
89buicklesabreL
Apr 27, 2005 10:10 PM
