04 Lesabre Path to Supercharged
Old Apr 29, 2024 | 04:43 PM
alexandrusmaximus's Avatar
Default 04 Lesabre Path to Supercharged
Hey everyone,
I am now an owner of a 2004 Buick Lesabre, and have been looking for something in the 3800 series to turn into a sleeker. While the h-body is not typically a very “moddable” platform, there are enough resources & reliable aftermarket options out there now to put it up in the running for a fun yet discreet street car.
I’ll be posting updates in this thread as much as possible, I plan on doing a few different steps or stages if you will
- Initial inspection / routine maintenance
-engine / transmission
-suspension
-interior / exterior
- Max out N/A & preparation for boost
- PCM & Tuning
- Fuel & Ignition
- Drivetrain
-Supercharger conversion
- Stock motor max out
- Begin Built motor (turbocharged)
- Custom Modifications
Initial inspection
I purchased this Lesabre for 3k cash, the first drive brought out some random misfires which I attributed to poor maintenance at the time.
After getting her home I did an oil change, replaced spark plugs & wires, removed & cleaned coil packs & module, removed the snap ring & mesh screen in the throttle body pre MAF (something shot through the intake, there was no filter, and ripped the mesh screen).
After that I was still getting a misfire, and it showed a pre-cat Oxygen sensor issue. Replaced that, and we continued to misfire. Checking again narrowed it down to a cylinder 1 misfire - checked gap (.056) on replacement NGK TR55, plug wire connections, and coil pack connection. Issue was resolved under normal driving conditions, but when under high acceleration I got yet another code. P0420 linked to catalytic converter issues. The converter will be replaced temporarily and soon I will be ordering a downpipe - resonator system from ZZP, along with their stage 1 PCM.
will post some pictures when I get home! Phones about to die haha
Old Aug 8, 2024 | 10:03 PM
NTX5467's Avatar
There used to be a website devoted to upgrading the 3800 Series II V-6. Something like "3800 Performance.com"? Almost all of the performance 3800 things come from the Pontiac Grand Prix people. Supercharger kits used to be available for the W-cars.
Better upgrade the chassis with some stiffer shocks/struts and the brakes with some good semmi-metallic linings. NO ceramics. Plus some better tires. Over the years, there were some performance Bonnevilles which might offer up some chassis and brake upgrades?
Enjoy!
jedd47
Mar 28, 2013 07:47 AM
jkrens
Aug 8, 2012 08:26 AM
KAD1
Mar 30, 2008 05:37 PM
village
Mar 26, 2007 12:12 PM
rmartin
Jan 31, 2005 12:55 AM
