01 LeSabre front struts replacement
I have been trying to take off the bolt/camber adjuster (top bolts) on the struts and can't get them loose. I've tried spraying with brake cleaner to loosen factory locktite (red stuff on bolt threads) heat and pb blaster used a impact gun and A 3' long breaker bar and bent that, I tried to tap bolts with the nuts on it. tried all this with it on the car then tried it off the car. I have looked on line at the junk yard one's and I know they aren't threaded all the way, so the breaker bar should have loosen them up. Please help!
dtachia
Apr 21, 2011 03:13 PM
dtachia
Apr 21, 2011 03:11 PM
