’95 Blower Motor Control Module/Resistor
Old Oct 4, 2006 | 02:09 PM
SubieHo's Avatar
The blower motor is not working on my father-in-law's 95 LeSabre
Limited with automatic climate control. The control panel seems to be
working just fine so I'm guessing it could be one of two issues:
1) Blower motor
2) Blower control module
Please share your experiences. Specifically, where are these parts
located on this car, and has anyone had problems with these
components. Thanks.
Edited by: SubieHo
Old Oct 4, 2006 | 03:14 PM
buckroo's Avatar
Which blower are you talking about, the heater or the radiator?
Old Oct 4, 2006 | 04:41 PM
SubieHo's Avatar
the heater --
engine cooling system is fine.
Edited by: SubieHo
Old Oct 4, 2006 | 06:11 PM
bassasasin's Avatar
These blowers have a history..
Check for voltages at the blower.
Good luck
Old Oct 4, 2006 | 07:02 PM
SubieHo's Avatar
I won't have access to the car until Thanksgiving when I go to visit my inlaws.
I am hoping that it's just the blower motor itself -- the control modulator is pricey.
Are the blower motors pretty accessible on LeSabres? On most cars, they're located underneath the glovebox on the passenger side.
I don't have any experience working on these cars so any help or instructions on removing internal trim for access to the blower would be greatly appreciated.
Old Oct 5, 2006 | 01:04 PM
bassasasin's Avatar
Its located mid firewall ... Engine compartment.
Somebook indicationsare that its possible that loose wiring may be the problem and could be an easier repair..
Good luck. Edited by: bassasasin
Old Oct 6, 2006 | 01:31 PM
buckroo's Avatar
[/QUOTE]
Bassasasin is correct that the blower is accessabel from the engine compartment on the firewall.
I looked at mine and it looks like the power is coming from the relay bank that is located on the firewall. You will have to remove the plastic cover to get access to them. I would check the relays for a malfunctioning one. To check which oneyou will just have to trace the main wire from the fan to it distanation. This would be the easiest to check.
Old Oct 6, 2006 | 09:07 PM
SubieHo's Avatar
Thanks guys, I'll check it out when I see them in a couple of months and report back with any news on this issue.
Old Oct 7, 2006 | 03:24 AM
  #9
bassasasin's Avatar
The troubleshooting guide recommends looking for power at the blower speed relay switch.
Settings.
Blower speed relay: REMOVED
Ignition switch: RUN
mode selector NORM
Blower switch: HIGH
Check pin 86 to 85 for Voltage if not check fuse 5D
Check voltage at pin 30 should get voltage.
Anyway theres a start.. without pulling the blower.
Good Luck
BASS
Old Nov 30, 2006 | 07:31 PM
  #10
SubieHo's Avatar
Thanks for the help, guys. Replaced the blower motor, and it now works.
andersson
Jul 31, 2007 07:25 PM
bgisse
May 24, 2007 04:23 PM
edeee2
Dec 24, 2006 08:04 PM
edeee2
Dec 24, 2006 07:43 PM
Dave42
May 23, 2006 02:13 AM
