Troubleshoot my 2011 LaCrosse CXL 2.4
Old Apr 9, 2023 | 04:31 AM
suzq's Avatar
Default Troubleshoot my 2011 LaCrosse CXL 2.4
Dash warning says AC is off due to hot engine. The car is not over heating. Top radiator hose is warm and flexible. Bottom condenser hose is not as warm as the top. Engine temp is not showing a reading with the needle resting below the C. It doesn’t move. Heat works great, but the cooling fans are running constantly even with the engine off unless I pull the fuse. Thermostat seems to be working. I replaced the ect sensor & reset the ecm. But fans are still running. I recently replaced fan, radiator & ac condenser along with the lower radiator sensor. It ran great for about a month, but now same warning keeps popping up … AC off engine hot. I did not recharge the AC after the condenser was installed. The fan is rattling & unusually noisy. Could a dysfunctional fan be throwing off the cooling system? I can’t figure this out.
Old Oct 21, 2023 | 01:39 PM
CWFJR's Avatar
My wire’s car did similar. AC compressor did NOT start. Had to turn AC on/Off”. The stealer replaced water pump… problem still there, but unrepeatable when being observed.
Dmurdock
Oct 28, 2020 05:43 PM
BuickBag
Jul 31, 2017 11:13 AM
rudy911
Sep 7, 2010 07:56 PM
Sentry95
Jan 29, 2009 03:15 PM
redrum3g
Mar 26, 2008 06:50 AM
