Grand National The Rear Wheel Drive Turbocharged Coupe that has remained a legend for decades
How much boost?
Old Jan 3, 2006 | 02:07 PM
GNXTC's Avatar
Just curious how much boost you can run an a GN? I was told as long as there is no knock then you are okay, is this true?
Old Jan 5, 2006 | 04:09 PM
Patrick's Avatar
Administrator
well, every engine has its limits...do you have an air to fuel gauge, and an eGt gauge?
Old Jan 5, 2006 | 07:57 PM
GNXTC's Avatar
Ok, here's what I have: Rebuilt w/ forged pistons, ported/polished intake & heads, 62mm throttle body, 3" exhaust & downpipe, #60 injectors, custom chip, te62 turbo, alcohol injected, K&N, 200R4 w/shift kit & 3400 stall, PTE front mount intercooler, EGT, boost, water temp, & oil pressure gauges. I'm going to install a different downpipe w/ an external wastegate. My boost gauge only goes up to #20, and I have pegged it all the way down to 6 o'colock, which I guess to be about #25, w/ no knock, that I could hear.[img]smileys/smiley20.gif[/img]
Old Jan 9, 2006 | 12:02 AM
ChevyIIman's Avatar
Well ive seen guys run them as high as 32+ with alky injection. With a forged bottom end and a fresh motor you should be good. But I suggest you get a boost guage that goes higher though. How are your Exhaust Temps?
andersson
Sep 19, 2007 05:56 PM
fastfurious
Feb 14, 2007 02:11 AM
turbo87
Jun 25, 2006 05:35 AM
