Window regulator
Old Mar 17, 2023 | 03:25 PM
Bwill's Avatar
Default Window regulator
Got a 93 Buick regal that the front passenger side window is working but going up and down crooked. I'm guessing regulator but can't find one new or used anywhere. Thoughts?
Old Mar 18, 2023 | 09:55 AM
Before jumping the gun, it would be a good move to remove the interior door panel and actually look for the problem because it may not be as complicated as you think.
Sometimes a bracket will come loose that contains the window channel or there may be a bolt that came out that holds the window to the regulator assy. They usually use 2 bolts.. You will need a few special tools to remove the panel , which will help prevent any damage to the cardboard.
With the window part way down can you move the window to straighten it? That should give you some idea of just what may be wrong.
Old Mar 19, 2023 | 09:27 AM
Bwill's Avatar
Yes as you have to help the window once it goes crooked halfway down to straighten it back up to make it roll up right.
Old May 22, 2023 | 04:10 PM
Bwill's Avatar
It's this part right here that is broke. I don't know the name of it so I can look for an aftermarket or whatever.....
Old May 23, 2023 | 05:29 AM
You could try a few auto glass shops or a dealership.
These are special parts and usually only a dealership parts dept will have/get them.
carid
Appearance
Mar 25, 2015 08:18 AM
Clacquam
Oct 21, 2014 08:03 AM
kroneck4
Apr 17, 2011 09:44 AM
bouttree
Jun 12, 2009 04:57 PM
RickMN
May 9, 2008 03:55 PM
