Replacements for sealed beam headlights?
Greetings
My Park Avenue got one-eyed so I need to replace at least one headlight.
Thing is, the sealed beam lights are expensive and hard to come by in my country, so I wonder if there are perchance any replacements to be found that use Halogen H4 or H7 lamps instead?
Hello liddy!
I eventually found out that my PA doesn''t use sealed beam lamps at all, it uses pretty standard halogens. So I found new at the nearest gas station.
It is a long story why I was mistaken about the lamp type, suffice to say that you should not listen too much to "experts" but rather see for yourself...
Thanks anyway, I shall most certainly look up that source you mentioned for other parts.
Friendly yours,
/Michail
Friendly yours,
/Michail
