CONSTANT HIGH OIL PRESSURE
Old Oct 6, 2005 | 12:41 PM
MrBSS's Avatar
I just realized thatmy oil pressure reads "Normal-129 PSI" at all times. This is on a '97 Park Ave Ultra with the Driver Information Center.
Seems like a loose wire or bad sensor. Anyone else seen this, andmaybe canprovide some guidance?
It does seem like a bad way to fail!
Old Oct 12, 2005 | 01:04 PM
Patrick's Avatar
Administrator
it also seems likea sensor issue to me.
Old Oct 13, 2005 | 02:28 PM
Erakiel81's Avatar
On some car a bad PCV valve will make a high pressure near the sensor...
Old Oct 14, 2005 | 12:38 PM
MrBSS's Avatar
Thanks for the input. I had recently replaced the PCV valve.
I replaced the oil (pressure) sensor last night, and it did solve the problem.
Terbronco7
Jun 2, 2013 05:15 PM
viaaedasonlines
Mar 5, 2009 02:26 AM
county
Feb 15, 2007 01:22 PM
administrator
Aug 8, 2005 09:02 PM
