I just realized thatmy oil pressure reads "Normal-129 PSI" at all times. This is on a '97 Park Ave Ultra with the Driver Information Center. Seems like a loose wire or bad sensor. Anyone else seen this, andmaybe canprovide some guidance? It does seem like a bad way to fail! |
it also seems likea sensor issue to me.
On some car a bad PCV valve will make a high pressure near the sensor...
Thanks for the input. I had recently replaced the PCV valve. I replaced the oil (pressure) sensor last night, and it did solve the problem. |
