95 park avenue vibration
Old May 5, 2006 | 11:13 AM
jerrysbuick's Avatar
Got this 95 pa that I love but I'm considering getting rid of cause it has a pretty bad shake at 75-80+mph on the x-way. I've replaced both front tie rod ends and ball joints, had a good alignment done and had 3 different sets of balanced tires on this thing in an attemptto get it to drive right.
I'm not too sure on where to go from here what should I check out next? the vibration is rough shakes the dash pretty hard at 75 but drives beautifully 30-70mph. I don't want to get rid of it but this is driving me nuts!
thanks
jerry
Old May 8, 2006 | 02:47 PM
MrBSS's Avatar
I assume you (or your mechanics) have checked the CV joints, right?
Old Jul 10, 2006 | 01:15 AM
samueljackson's Avatar
u changed the tires, what about the rims, one bent rim would do that as well
Old Aug 9, 2006 | 06:04 AM
mrbuick's Avatar
I have the same problem with my 92 P.A.. My mechanic replaced the axle shocks to no avail. then I took the car to a transmission mechanic. He mentioned that the problem was a worn out bearing/seal in the tranny????
Old Aug 13, 2006 | 03:23 AM
mrbuick's Avatar
Does anyone have any other suggestions on the shaking of the p.avenue other than transmission mechanic suggesting the axle connection at the tranny be inspected for some kind of a worn out bearing or seal??? I have never heard of this, have you? please help.
mine shakes on the freeway only at about 55-70 mph.
garllo
Oct 22, 2008 04:27 AM
rc454
Nov 22, 2006 04:16 PM
Racer
Jul 23, 2006 01:50 PM
eurotraveler
Apr 19, 2006 12:10 AM
bigshooter9270
Apr 9, 2006 06:10 PM
