94 le sarbre no start... HELP
Old Jul 16, 2008 | 09:30 PM
nissantech25's Avatar
i have 3.8l 94 lesabre that wont start. new ignition module and battery put in. ignition module started to spark and would not crank. i started to tap the coil packs and the check engine light came on and started to crank. i have fuel but no spark.. lead me in the right direction?
thanks ryan
Old Jul 20, 2008 | 03:34 PM
samueljackson's Avatar
I would start to suspect the crank position sensor. but before just buying a new one, I would check the resistance in the wires from the sensor to the ICM. and also from the ICM to the PCM. heres a schematic that tells you the pin-outs.
and heres a thread that may help you as well
http://www.pontiacbonnevilleclub.com...wtopic.php?f=1 9&t=2371&start=0
Old Aug 9, 2008 | 12:41 PM
i have a new problem. i put wires and plugs in and it started.
now i have absolutely no power in the dash lights, centre console, interior lights and it wont even crank over.
i was trying to find the voltage that the alternator was putting out and as soon as i touched the probes from the multimetre to the battery post everything cut out and now i have nothing.
i checked all the fuses under the hood and under the drivers side dash and they all have power. when i checked the fuses under the passenger side dash i found i had no power to misc engine control, ecm, fuel pump, and ignition. i changed the fuses and now have power flow but still have no lights.
any ideas?
Old Aug 19, 2008 | 02:23 PM
bookie0116's Avatar
Wow
1986Century
Sep 25, 2011 06:02 PM
blu3g
May 20, 2008 05:43 AM
