white smoke
Old Feb 26, 2010 | 02:25 PM
rick02camaro's Avatar
Default white smoke
hey my dads got a 99 park ave with a 3.8 non supercharged. it blows white smoke out of the exhaust but not all the time. its coolant because the overflow bottle gets low and the low coolant light comes on. do you think it might be the intake gaskets rather than the head gasket? how can you check the intake gasket?
Old Mar 9, 2010 | 08:19 AM
samueljackson's Avatar
The head gaskets are extremely rare to fail on any 3800. Regardless of mileage, if the intake gaskets are original, that is most likely the issue. I'd recomend changing the lower gaskets with the steel gaskets, and replacing the upper intake as well as the gaskets all at once.
check out www.rockauto.com they have the dorman kit for only $80 for the upper. And the steel gaskets for $52. couldnt find pic on their site, but got one in link below
steel gasket here http://www.oreillyauto.com/site/c/de...2293&ppt=C0026
Old Mar 10, 2010 | 04:33 PM
Default thanks
hey thank you for your help. i will try that and see what happens! thanks
jpabberstein
Sep 12, 2010 05:56 PM
electra-fied
Apr 8, 2006 08:34 AM
