Get scan codes &ABS 94 Century 2.2
Old Nov 5, 2006 | 10:45 PM
grayelve's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
HI All Need Help ... I am trying to get ABS codes. My wheel sensors and cables check out good with a meter. The ABS drops out and traction light come on when I am near the end of a stopping action then goes off when I ease up on the brake. No leaks, caliper seals dry, brake cylinder seals dry, ABS disconnected have normal stopping behavior and no peddle fade. This 94 Century is a fluke, I have been looking at scanners upto the $300 to $400 range without luck. Gm obd1 with 12 pin dlc jump pins A&amp; B to get codes. I have A, K, and M to work with. Schematic with dlc lines would help, any and all info would be great. A scanner name and number? My full appreciation to you if you have the savy I'm looking for. grayelve
Daddioman
May 21, 2008 08:21 PM
JoeT
Apr 23, 2008 04:50 PM
samueljackson
Jan 19, 2008 12:09 PM
Timebuilder
Jan 14, 2008 07:12 PM
