2003 buick century
Old Jun 8, 2022 | 04:52 PM
Connie33's Avatar
Default 2003 buick century
Hi. All dash lights flicker off and on. Car won't turn over. Battery and alternator has been checked. They are good. A new starter was put in. A ignition switch and lock cylinder with key was also replaced. There's also a new starter relay that was just put in. Any ideas what to check next?
Old Jun 9, 2022 | 05:40 AM
A known problem area is where the positive battery cable attaches to the battery. Look at the surfaces and you will usually find corrosion there.
There is a long distance between the battery and the engine, battery in rear of vehicle. Check the cables and connections , both ends of both cables.
Old Jun 9, 2022 | 04:27 PM
Connie33's Avatar
yes I have checked and the battery cables are clear. The battery is fully charged. So there is no problem with battery or connection.
Lonesome Dove
Mar 17, 2021 03:23 PM
Alexandru Balescu
Jul 14, 2019 12:04 PM
patcal
Jul 17, 2017 05:37 AM
Triggerhorse
Aug 23, 2012 10:01 AM
painter1
Feb 13, 2007 11:50 AM
