1999 century custom fan problem
Old Oct 18, 2006 | 04:51 AM
burgerwitfry's Avatar
hi, i have a question concerning the dual electric fan of mines because i was driving one day and realized that my fans sudden stop working so im wondering what is problem and can i fix this or do i have to bring it to the dealer? any help would be greatly appriciated, thanks
Old Oct 18, 2006 | 12:28 PM
MrBSS's Avatar
Well, there are quite a number of things which could causeelectric fans to stop, some of them normal.
If your engine is starting to overheat, I would check the fuses and relays (see Owner's Manual or Chilton's or similar at the library). Past that, we might be able to help with more data, but, unless you are real short of money, you probably should take it in. Doesn't have to be a dealer, though.
Old Oct 19, 2006 | 03:19 AM
i did some searching and test if my fan actually work by unpluging the (TPS) or whatever it was called next to the thermostat and turning the engine on.
i found out the fans does work, but it seem like it does not turn on when the engine gets hot for some reason, so what does this mean? thanks
dtachia
Apr 23, 2011 02:51 AM
rudy911
Sep 7, 2010 07:56 PM
Lammersd
Mar 21, 2010 02:25 PM
Nitrocrushr
Jul 29, 2009 06:58 PM
JKropetz
May 6, 2009 03:10 PM
