1992 Buick century hesitation
Old Apr 9, 2006 | 11:05 PM
Mike C.'s Avatar
Hello, This is in response to the "Hesitation" issues on my '92 3.3 century with sluggish power/hesitation that started at just highway speeds..and now has progressively got worse with no codes and barely drivable @125,000 miles. I changed ICM no help, and the fuel pump as well, with no results, fuel pressure reading @39lbs. book says 25~44. Has anyone changed the cat converter to relieve this problem? If so did this work. Thanks, Mike
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Apr 11, 2006 | 06:31 PM
Poormanq45's Avatar
Try cleaning the MAF sensor.
I have the same year, but haven't had it long(~2 months). SO I'm not sure if this car has one though, but on my '92 Q45 that was the cause of the problem you described.
Old May 23, 2006 | 02:02 AM
Toadster25's Avatar
yep. try cleaning the Mass air flow sensor.
Old May 23, 2006 | 02:21 PM
MrBSS's Avatar
Unless this has been done recently, I would replace the spark plug wires.
19RMW92
Aug 25, 2008 01:28 AM
Desperate
Jun 13, 2008 12:51 PM
matcoor
Apr 18, 2008 09:13 PM
jinjerr86
Jun 9, 2007 10:37 PM
KillaCam
Jul 26, 2006 10:38 PM
