Appearance Talk about your interior and exterior mods here...
rusty floorboard repair
Old Aug 10, 2006 | 07:39 PM
cmbj's Avatar
Hello,
I just bought a 1962 Buick Skylark convertable. It needs a new top and needless to say, rusty floorboards repaired. Is it possible to remove a small section at a time and weld in new sheetmetal? Luckily, it appears to be relatively flat in the bad areas. What gauge metal should be used? Any advice would be appreciated.
thanks,
JamesEdited by: cmbj
Old Oct 12, 2006 | 01:11 AM
samueljackson's Avatar
idk, what gauge is a stop sign?
Old Oct 13, 2008 | 04:49 AM
Rusty's Avatar
Originally Posted by cmbj
Hello,</font>
I just bought a 1962 Buick Skylark convertable. It needs a new top and needless to say, rusty floorboards repaired. Is it possible to remove a small section at a time and weld in new sheetmetal? Luckily, it appears to be relatively flat in the bad areas. What gauge metal should be used? Any advice would be appreciated.</font>
thanks,</font>
James</font>
I''d just get a set of cheap set of after market floor pans, your local body shop should be able to tell you the cheap places to get them.
Old Oct 29, 2008 | 10:01 AM
TrippleT's Avatar
ether that or you can just get sheet metal
and cut peaces out and place new in...
just make sure you do it in squares or your going to have
a fun time matching the part you cut out...
sobbygob
Jun 8, 2008 05:08 PM
daviddc114
Jun 6, 2008 04:22 PM
JoeV
Oct 11, 2007 10:55 AM
tashabelle
Apr 2, 2007 03:11 PM
98buickcentury
Feb 1, 2006 12:27 PM
