Suspension Talk about your suspension within...
Disc brake conversion
Old Nov 8, 2005 | 05:51 PM
RSXS34's Avatar
I own a 1972 Skylark custom with front drums and want to convert the to disc. My question is would i have to get the proportioning valve or just the master cylinder?? and what other cars should i look for that use the same setup other than Chevelle??
Old Jan 5, 2021 | 10:42 PM
Fred Kiehl's Avatar
You may have a proportioning valve, but if you do not, get one. They are relatively cheap. You can even get adjustable ones. If you do not have a dual system, get a new master cylinder, and plumb it for a dual system...front and rear divided. I do not know what else you would use for the spindles with disk brakes.
Old Feb 13, 2026 | 04:57 PM
Chitownmike's Avatar
Default Disc brake conversion
When converting to dice brakes do you have to change to 15 “ rims to fit the disc brake calipers?
redhorse
Mar 11, 2018 05:38 AM
jayhovah1982
Nov 20, 2011 02:49 PM
The_Stuff
Apr 27, 2008 04:18 AM
Segaman
Mar 16, 2007 07:58 PM
62SkylarkGirl
Jan 1, 2007 08:29 PM
