wont stay running
Old Oct 21, 2008 | 01:35 PM
whatadeal's Avatar
[img]smileys/smiley19.gif[/img]I have a 91 Riviera, have replaced battery and key ignition module.Car will start,run momentarly then stop, will restart again and again but not continue to run. Mechanic says its not the fuel pump.Is this a anti-theft issue or what else could it be? Car was properly re- keyed to recognize new module. Help! damsel in distress.
Old Oct 22, 2008 | 04:35 AM
TrippleT's Avatar
did you get a remote start put on?
or a security system?
Old Oct 25, 2008 | 06:49 PM
whatadeal's Avatar
No remote controll or security system installed aftermarket. Good ideas, keep them comming guys.
Old Oct 26, 2008 | 10:15 AM
TrippleT's Avatar
fuel pressure is good
and fuel filter is new?
plugs are all good
wires are all good
fuel pressure regulator
timing
plug wires are correctly put in
coil packs are good
fuses are all good
any of them?
air way is ok? the thing doesn''t have a freakin chipmonk in the air intake does it?
hydro lock ?
there could be a million things
get a video of what its doing
finaly
Put a few gal of new gas in it.... could be bad gas
Old Oct 27, 2008 | 02:23 PM
Rusty's Avatar
are you getting any codes? when it cuts off, I take that everything else stays running, like the radio and lights? How long does it run, and when you say it starts right back, you mean just turn the key and it starts?
Old Oct 27, 2008 | 02:29 PM
Rusty's Avatar
oh yeah, try this, when it starts hold the pedal all the way down, see what happens. Why did you rekey it? buy it used? did it sit any? It could well be the pick up in the tank is plugged, and when it cuts off the back wash from the lines clears the blockage.
Old Oct 28, 2008 | 11:54 AM
TrippleT's Avatar
^^^^ i agree with rusty
did some one put an egg in your gas tank?
jvm
Sep 27, 2012 11:29 AM
1990buickcentry
Jun 28, 2010 04:48 PM
scott
Jun 28, 2010 02:39 AM
stone
May 25, 2006 12:59 AM
