Supercharged engine is over heating
Old Apr 14, 2010 | 12:05 PM
Adam93's Avatar
Default Supercharged engine is over heating
My 1996 buick riv has trouble codes stating that i have a cyl 4 misfire. i figured blown head gasket, i just replaced the supercharge belt and took it out and my check engine light came on and started blinking, and the car chugges. Any info on possible problems or if you want more info plz contact me.
Old May 29, 2021 | 02:21 PM
kink56's Avatar
Not sure about the overhearing, yes, that could be a head gasket. But as for the other problem. For me all it took was to replace the coil pack.
Old May 30, 2021 | 11:40 AM
Before replacing anything, why don't you consider switching spark plugs between the cyl next to #4 and #4. That way you might get away with just a plug replacement.
Compare the appearance of the plug from #4 cyl to any other plug. If compression is getting into the cooling system when the engine cools down it might just pull some coolant into the cyl and the white bubbled appearance of the plug could confirm a coolant leak.
There is a way to verify if combustion is getting into the cooling system. Some shops have a combustion tester to detect if compression is getting into the cooling system by measuring any air coming out at the radiator fill.
royal son 2011
Apr 1, 2015 11:43 AM
hellozaizai
Mar 4, 2013 12:51 AM
redhawk77
Jun 13, 2008 03:56 AM
blu3g
May 6, 2008 06:39 PM
electra-fied
Mar 28, 2006 02:19 PM
