Head Gasket
Old May 31, 2008 | 11:57 AM
  #11
redhawk77's Avatar
Looked ok cleaned it up auto zone gave me the lbs, 4 lbs on the bottom
intake and 22 on the top intake of tourk? Is that right I thought that the
bottom shouldbe 22 and the top 4 But did what they said ..Edited by: redhawk77
Old Jun 1, 2008 | 12:06 PM
  #12
redhawk77's Avatar
Ok I just got back from Checking things out the cyc compression across the
front 30,50,60 so I'm guessing It's blown , Now I have to decide if It's new
car time or fix it again ...............Thanks Samuel what do you think ???Head
gasket has to be a pain??
Old Jun 12, 2008 | 05:41 PM
  #13
samueljackson's Avatar
yeah, those #s are way low. should be in the area of 170 iirc. the HGs on the 3800 are very stout and reliable. if there was a problem bad enough to cause this, it may be safe to say that engine damage has already occurred. so i wouldn''t just change the hg. I would say a piston rings, and rod/crank bearing change would be a minimum.
If i were you, I would weigh out the cost of a engine rebuild vs a new car.
Or you may consider a yard motor. An L36 should be fairly cheap and easy to find. but if you go that route, go with caution, bc no engine likes to sit for a long period of time. so I would try to find a 3800 powered car that was recently wrecked.
Old Jun 13, 2008 | 03:56 AM
  #14
redhawk77's Avatar
Thanks Ya Already got her another car not the best but it works ,and lookin for a yard motor ,Thanks for all your help ! talk at later Dave I''ll keep you up dated ....
cclark1894
Apr 5, 2013 09:23 PM
hellozaizai
Mar 4, 2013 12:51 AM
Kawrider
Feb 11, 2009 03:07 PM
electra-fied
Mar 28, 2006 02:19 PM
BigRich
Jan 6, 2006 09:57 PM
