-   Rendezvous (https://www.buickforum.com/forum/rendezvous-27/)
-   -   2006 Rendezvous Manual Lever for seat recline. (https://www.buickforum.com/forum/rendezvous-27/2006-rendezvous-manual-lever-seat-recline-6803/)
William Morton Nov 10, 2013 12:34 PM
My 2006 Rendezvous Driver Seat Manual Lever to recline the is broken and it does not feel like it is connected to anything when I pull it. Is this a common problem with the Rendezvous?
The electric seat controls are working correctly only the manual lever that you pull up on is broken.
Ruben Girona Mar 13, 2015 08:49 PM
Same issue
I was having the same issue but i took mine apart and found that this metal ring with a tooth to grab the bar was turning in the plastic handle. I just drilled a small self tapping screw through the other side of the tooth and vuala keeps the metal from freely moving. (make sure the screw goes through the plastic handle):D:D:D:D:D:D
