supercharger HELP!!!
Old Apr 28, 2008 | 08:21 AM
jeremy24's Avatar
i have a 1997 buick regal gs i was wondering if anyone could tell mehow to boost the psi on the supercharger? ........much help needed
Old Apr 28, 2008 | 03:11 PM
samueljackson's Avatar
before you raise the boost you want to make sure your engine is running to its full potential now. if you are unsure of the last tune up, i would suggest new plugs, and wires at the minimum.
after that, you need to scan the pcm and make SURE you have 0 KR (knock retard).
when that is all good, i would suggest a fwi, or a cai of somesort.
then think about raising the boost. you can achieve this by simply putting on a smaller pulley. you can get a press on pulley for about $60. but you may look into the modular pulley systems. more commonly refered to as MPS. those you can easily swap out pulleys with just a few bolts.
for the first pulley drop i would suggest a 3.5 inch. and after that you need to scan again and make sure you still have 0 kr.
Golden
Dec 15, 2018 03:04 AM
the user
Feb 15, 2018 03:53 AM
98GS
Apr 7, 2007 06:25 PM
jerrywc01
Apr 1, 2007 08:12 PM
gtrick
Feb 3, 2006 02:14 PM
