start
After it is run at operating temp and shut down it will not start unless it has cooled down to ambient temp.It turns over and fiers but will not catch. Battery is good and plenty of gas.
check for spark in the front 3 cylinders. should be blue. if you have an extra plug layin around, even a lawn mower plug or sumthing. then you dont have to take the plugs out to check. just pull the wires and put the extra in the wire, and have someone turn the key.
if you have good spark, then check the fuel pressure with a gauge at the rail.
Originally Posted by aldanan
yes i know have some experience with auto repair but being 71 yrs old i have not kept up with all these new fangeld eng controls.
ok sorry, no offense meant by that, i just wanted to toss it out there so you didnt get a false result.
cheers,
Wes
