Regal 93, 3.1 stall on the go
Hi, I live in Russia, and I have Regal ''93 3.1l.
For last 10-15 days I''m experiencing ''''stall problem''
The car is simply cut off on the go, with accelerator pedal pushed...
It does not matter, if the engine is cold or hot, but mostly when it''s hot.
"check engine" light does not come up . I have tried to pull some error
codes using the paper clip, and yet no codes were found.
Does it look like the ICM fault or the fuel injectors fault...
The reason I''m finking of the ICM or the FI fault is what the engine some
times just cut of, but some times it goes down to 600-700 RPMs and then
returns back to the normal driving mode (neither if I''m going straight nor
if I''m driving throughout deep corner...) + I have fuel pump & filter replaced lately.
P.S. The T outside is about -15 -17 C (it''s about 0 to -1 F) may by it has
something to do with it.
