Number of teeth in starter gear that engages in the flywheel or torque converter
Old Jul 8, 2015 | 07:21 PM
bighank's Avatar
Question Number of teeth in starter gear that engages in the flywheel or torque converter
Pulled 3 starters at the junkyard to replace one that has a bad solenoid.
Have a 2002 Buick Regal LS with 3800 series II engine.
Found some on 3100 engines and one from a 3800.
My starter has about 10 teeth on the gear that engages the flywheel. Some of the ones I pulled had smaller gears with only about 8 teeth.
Why the difference?
Also one GM Delco starter was slightly longer (about 1/2 inch) than mine and had a small black hollow tube about 1 inch long at the rear of the starter and at the bottom. It fell off when I touched it. Looks like it might be a drain hole in case some water gets in to the starter. What is this really for?
tvsdprasad
May 21, 2015 05:56 AM
wnlewis
Mar 29, 2013 01:07 AM
lucas30
Sep 22, 2011 03:02 AM
graat
Mar 24, 2010 04:11 AM
