-   -   mass air flow (https://www.buickforum.com/forum/regal-1973-2004-23/mass-air-flow-6302/)
feltes94 Jul 22, 2012 05:10 PM
mass air flow
i have a 2000 buick regal ls where would io be able to locate the mass air flow sensor ?
2k2cse Jul 22, 2012 08:11 PM
I'm not 100% sure where it is on the 3800. If it's not by the air box, it might be a part of the throttle body.
hanky Jul 23, 2012 05:07 PM
To help locate the MAF sensor just trace the air intake tubing from the air filter assy.
It is located between the air filter and the throttle body.
Just look for a black box type assy with three wires going to it .
feltes94 Jul 23, 2012 06:05 PM
ok thank you i found it also i was thinking about putting a cold air intake on but they do not make one for a 2000 buick regal and also what is in the air box besides the air filter?
hanky Jul 23, 2012 07:05 PM
IAT, Intake air temp sensor.
2k2cse Jul 24, 2012 07:02 PM
The PCM (computer) is in the air box. You can just zip tie it to where the air box mounts, or you can pick up a PCM tray from a Blazer/S10 and install that.
Merc6 Oct 25, 2012 10:38 AM
The S/C intake kits work on N/A Regals/Centuries depending on where your coolant over flow and washer fluid tank is located or relocated.
