MAP MAF ECU ?
Old Sep 21, 2007 | 07:31 PM
lefty2053's Avatar
A friend has a car he is trying to fix. 1998 Regal 2.8.
He has changed out the MAF, MAP and computer module. The car sputters all the time while driving with no power. After he bought the MAP, he took it back out and the car drives great without it. It is a new part and I told him it could still be bad but I am no expert by far. Any ideas why it runs great with out it and sputters with it in? He says the cat has been removed on this car as well so it couldn't be plugged up.
Old Sep 21, 2007 | 10:09 PM
samueljackson's Avatar
98 regal did not have a 2.8L.
and the only 3.8s ( if thats what he has???) that had both map anf maf, the map was useless.
the reason for this is the 3800s that came with both, were supercharged. the maf is used by the ecu to control aif fuel mixture, the map was SOLELY used for a boost gauge.
Is this maybe a 1988, or is it a 3.8?
more info please
Old Sep 22, 2007 | 03:06 PM
lefty2053's Avatar
Sorry about that, it is a 1988. Even he forgot it was a 88 and not 98. Got to remember he and I are on our last legs as well. Memory is our problems. Any help is appreciated.
Old Sep 22, 2007 | 03:20 PM
its ok, it happens,
arethe wires from the sensor to the ecu corroded? maybe check the resistance from pin to pin. should be close to zero ohms.
but i just wanna ask, this car has both a mass air flow, and a map sensor???
Old Sep 22, 2007 | 06:29 PM
lefty2053's Avatar
Both MAP and MAF. Will check the wires. He also has checked the Temp sensor and ithas 3 volts in and only 2 leaving. Is this normal?
Thanks for your help.
Old Sep 22, 2007 | 07:32 PM
well, i dont know the voltage for it, but the specs are going to be in resistance.
can you check the resistance on it when cold, the check the res when hot.
ill check for the specs, while you get the measurements. (tomorrows fine 4 me if its fine 4 you.)
Old Sep 22, 2007 | 07:50 PM
lefty2053's Avatar
Tomorrow is fine. He told me that when the car is cold it was 0 Ohms. When the car was warm with the key off it was 264 ohms and when warm and the key turned on it was back to 0 ohms. This is the Temp Sensor. Still haven't tested the wires to the ECU. I will have him do that in the morning.
Old Sep 23, 2007 | 03:40 PM
that sensor is bad, i dont need to look at the specs, given those numbers.
ill still look em up to know the exact, but cold should be high and warm will be lower resistance.
Old Sep 23, 2007 | 03:48 PM
  #9
ok idk what temp cold and warm was, but ...
68*F = 3520 ohms
158*F = 467 ohms
212*F = 177 ohms
edit- and in your reference to the voltage, i read that, during normal operating temp (195*F) voltage should be between 1.5 and 2.0 volts.Edited by: samueljackson
Old Sep 24, 2007 | 08:28 AM
  #10
lefty2053's Avatar
I'll let him know about the sensor and after he checks the ECU wires I will let you know about it as well.
