fule gage problems
Old Nov 17, 2011 | 02:44 PM
feltes94's Avatar
Default fule gage problems
when first start the car it reads empty for at least 5 min then it goes to full and stays ik that the tank is full but i want to know if its because the car reads gas once in a wile i am use to my gage always reading constently
Old Nov 17, 2011 | 04:28 PM
The gauge reads constantly. You might have a bad sending unit, float, or a bad connection somewhere.
Old Nov 21, 2011 | 09:59 AM
feltes94's Avatar
ok but for some reason it works when car is off and only when key is in on but when car running doesnt work
Old Nov 21, 2011 | 02:56 PM
Might be a good idea to check the ground circuit for the gauge assy.
Old Nov 30, 2011 | 09:58 AM
feltes94's Avatar
i am just going to replace the whole thing because i have to work on lot of things i have dripps from my oil pan
Old Feb 15, 2012 | 03:00 PM
feltes94's Avatar
i put new fuel pump in and now everything works perfectly
Old Feb 16, 2012 | 10:33 AM
Merc6's Avatar
Which brand did you get?
Old Feb 21, 2012 | 03:02 PM
feltes94's Avatar
i went threw napa i not really sure what brand by dad got it for me
Old May 10, 2012 | 02:06 PM
  #9
huey286's Avatar
Can't find where to start new thread, so will post here. 98 Lesabre pcv valve from O Reilly pulls too much vacuum thru crankcase, and sucks oil thru intake. oil goes down too fast, and if remove oil filler cap, eng slows like big vacuum leak. I'm told only AC Delco valve works right in these 3800's. will try one for $8, only from dealer. all after-market ones must let too much air thru. Is that right? huey286
buickbob
Dec 7, 2011 10:05 PM
county
Feb 15, 2007 01:22 PM
jerry1967
May 30, 2006 09:59 PM
