New to 6 volt
Old Sep 24, 2023 | 06:00 PM
53special53's Avatar
Default New to 6 volt
I recently purchased a 1953 Buick Special and noticed that the 6 volt battery positive was connected to the ground strap is this correct? Also what's all involved to convert to 12 volt system? Does everything electrical need to be upgraded or replaced? Any information would be greatly appreciated!
Also where is the best couple of places to order parts for 1953 Buick Special?
Old Sep 25, 2024 | 05:47 PM
andrew 53's Avatar
Hi did you ever get anywhere with this. I also just purchased a 53 and noticed the same thing.
thanks,
Andrew
Old Sep 25, 2024 | 07:43 PM
thanks,
Andrew
I ended up buying a 12 volt conversion kit with a new hi torque starter..
If you can find one try and 8 volt battery first or i suggest 12 volt conversion with HEI conversion on original distributor. Good luck!
Old Sep 26, 2024 | 06:27 AM
andrew 53's Avatar
Thank you for the reply. I don’t see an issue yet. I’m still going through it. I did hook the battery up wrong to start. This may of caused a fuse to blow in the radio. I’m also unsure if the generator is charging the battery. I need to dive a little deeper.
All the best.
RobertRichard
Jan 23, 2021 03:07 AM
RobertRichard
Dec 6, 2020 03:02 AM
bruce
Headers, Intake, & Exhaust
Sep 17, 2020 08:56 AM
spyderman
May 5, 2016 04:32 PM
spyderman
Mar 12, 2007 12:59 PM
